Philips 240B7QPTEB/00 24"1920x1200 VGA HDMI DP USB Monitor
£225.00
Delivery:
Standard: 1-3 working days
Key features
  • B Line
  • 24 (Viewable 24.1"/61.1 cm)
  • WUXGA (1920 x 1200)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, VGA (HD-15)
Product codes
The Philips PowerSensor display using post-consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description Philips Brilliance B-line 240B7QPTEB - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 26 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 53.3 cm x 25.7 cm x 54.9 cm
Weight 6.57 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, EPA, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 240B7QPTEB/00...
£225.00
