Philips 241B7QPJEB/00 23.8" 1920x1080 VGA HDMI DP USB Mo...
Philips 241B7QPJEB/00 23.8" 1920x1080 VGA HDMI DP USB Monitor
Select:
Key features
  • IPS technology for full colors and wide viewing angles
  • Edge-to-edge glass and narrow border for seamless appearance
  • SmartImage presets for easy optimized image settings
  • LowBlue mode for easy on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Built-in stereo speakers for multimedia
  • USB 3.0 enables fast data transfers and smart phone charging
  • SmartConnect with DisplayPort, HDMI and VGA connections
  • Sustainable Eco-design
  • PowerSensor saves energy costs
Product codes
The Philips PowerSensor display using 85% post consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity. IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90 degree Pivot Mode. Unlike standard TN panels, IPS display gives you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
The advanced Philips display features ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming graphic design and professional applications the ultra-narrow border display gives you the feeling of using one large display. SmartImage is an exclusive leading edge Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user-friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimizes the contrast, color saturation and sharpness of images and videos for ultimate display performance.
Philips Brilliance B-line 241B7QPJEB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Textured black with black stand
54.1 cm x 25.7 cm x 49.2 cm
5.83 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, EPA, cETLus, CU-EAC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241B7QPJEB/00...
