Philips 241B7QPJKEB/00 23.8" 1920x1080 VGA HDMI DP USB M...
Philips 241B7QPJKEB/00 23.8" 1920x1080 VGA HDMI DP USB Monitor
£187.95
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology for full colors and wide viewing angles
  • Edge-to-edge glass and narrow border for seamless appearance
  • SmartImage presets for easy optimized image settings
  • LowBlue Mode for easy on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Webcam pops-up when you need it, tuck it away when you don't
  • Built-in stereo speakers for multimedia
  • USB 3.0 enables fast data transfers and smart phone charging
  • SmartConnect with DisplayPort, HDMI and VGA connections
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The Philips PowerSensor display using 85% post consumer recycled plastics and PVC, BFR-free housing is ideal for eco-friendly productivity. IPS display uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90 degree Pivot mode! Unlike standard TN panels, IPS display gives you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
The advamced Philips display features ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. SmartImage is an exclusive Philips technology that analyzes the content displayed on your screen and gives you optimized display performance. This user friendly interface allows you to select various modes like Office, Photo, Movie, Game, Economy etc., to fit the application in use.
Product Description Philips Brilliance B-line 241B7QPJKEB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 24 W
Features 2.0 megapixel camera, USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 54.1 cm x 25.7 cm x 49.2 cm
Weight 5.83 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, EPA, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241B7QPJKEB/00...
£187.95
