Philips 241B7QPTEB/00 23.8" 1920x1080 VGA HDMI DP USB Mo...
£202.21
Delivery:
Standard: 1-3 working days
Key features
  • Brilliant performance
  • Edge-to-edge glass and narrow border for seamless appearance
  • Designed for comfortable productivity
  • Built-in stereo speakers for multimedia
  • USB 3.0 enables fast data transfers
  • Sustainable design
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, VGA (HD-15)
Product codes
This Philips monitor offers crisp views and efficient performance. Plus, with PowerSensor, it is ideal for eco-friendly productivity.
Product Description Philips Brilliance B-line 241B7QPTEB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 24 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, 2xDisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 54.1 cm x 25.7 cm x 52.7 cm
Weight 6.07 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241B7QPTEB/00...
£202.21
