Get your best work done with the Philips 24" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height-adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description | Philips B Line 241B8QJEB - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class D | Energy Consumption per Year | 26 kWh | Power Consumption (On mode) | 14 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.275 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 103.8% sRGB, 89.9% NTSC | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black texture | Dimensions (WxDxH) - with stand | 54 cm x 20.6 cm x 50.8 cm | Weight | 4.97 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CB, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 76 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Multilingual |
Features | Sync on Green, SmartImage, SmartConnect, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, EasyRead |
Dimensions (WxDxH) | 54 cm x 20.6 cm x 50.8 cm - with stand |
Weight | 4.97 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB 3.0 (fast charging) , USB 3.0 , 2 x USB 2.0 , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+30 |
Swivel Angle | 350 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 14 kWh/1000h |
Power Consumption (Typical) | 13 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54 cm - depth: 20.6 cm - height: 50.8 cm - weight: 4.97 kg , Without stand - width: 54 cm - depth: 5 cm - height: 32.3 cm - weight: 3.37 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 60 cm |
Shipping Depth | 19.8 cm |
Shipping Height | 46.8 cm |
Shipping Weight | 7.17 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
