Philips 241B8QJEB 24" 1920x1080 5ms DVI HDMI LED Monitor
£151.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology for full colors and wide viewing angles
  • 16:9 Full HD display for crisp detailed images
  • SmartImage presets for easy optimized image settings
  • LowBlue Mode for easy-on-the-eye productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £155.05
Save £1.50
Get your best work done with the Philips 24" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height-adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 241B8QJEB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A+
Energy Consumption per Year 26 kWh
Power Consumption (On mode) 18 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Colour Black texture
Dimensions (WxDxH) - with stand 54 cm x 20.6 cm x 50.8 cm
Weight 4.97 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CB, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241B8QJEB 24"...
£151.56
