Philips 241P4QRYES/00 24" 1920x1080 VGA DVI Monitor
£236.54
Delivery:
Key features
  • ErgoSensor for a healthier way of working
  • Neck posture detection and corrective advice
  • Optimal viewing distance measurement and advice
  • Time-break reminder
  • AMVA LED for wide-view super-high contrast, vivid images
  • DisplayPort offers audio and video over a single, long cable
  • SmartImage presets for easy optimized image settings
  • Zero power consumption with 0 watt hard switch
  • 65% post consumer recycled plastics with TCO Edge
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Low bezel-to-table height for maximum reading comfort
Product codes
The innovative Philips ErgoSensor monitor is the world's first intelligent display that can advise you how to sit in an ergonomically correct position at your computer screen.
Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, movies, gaming, and demanding graphical applications. It is optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in 90 degree pivot mode.
Philips Brilliance P-line 241P4QRYES - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black, textured silver
56.5 cm x 22 cm x 52.1 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0, cETLus
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241P4QRYES/00...
£236.54
