Philips 241P6EPJEB/00 24" 1920x1080 VGA DVI HDMI Monitor
£174.98
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • P Line
  • 24 (23.8"/60.5 cm diag.)
  • Full HD (1920 x 1080)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
Product codes
Designed for you, the Philips Brilliance monitor features SoftBlue LED Technology to protect your eyes and deliver brilliant colorful images for maximum productivity
Product Description Philips Brilliance P-line 241P6EPJEB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 26 W
Panel Type ADS-IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 53.1 cm x 25.6 cm x 42.2 cm
Weight 6.47 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, PSB, WEEE, CECP, EPA, cETLus, RCM, CU-EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 241P6EPJEB/00...
£174.98
