We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description | Philips S-line 243S5LHMB - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Energy Consumption per Year | 32 kWh | Power Consumption (On mode) | 17.5 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.272 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 10000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50 - 60 Hz) | Colour | Black with hairline texture | Dimensions (WxDxH) - with stand | 56 cm x 23.2 cm x 52 cm | Weight | 5.12 kg | Environmental Standards | TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus, RCM, Ukraine |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.6" |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, SmartResponse, Mercury free |
Dimensions (WxDxH) | 56 cm x 23.2 cm x 52 cm - with stand |
Weight | 5.12 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , HDMI , Headphones , Audio line-in |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 175 |
Rotation Angle | 90 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | VGA cable , HDMI cable , Audio cable |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 17.5 kWh/1000h |
Power Consumption (Typical) | 14.9 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56 cm - depth: 23.2 cm - height: 52 cm - weight: 5.12 kg , Without stand - width: 56 cm - depth: 5.3 cm - height: 34.8 cm - weight: 3.17 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62 cm |
Shipping Depth | 19.1 cm |
Shipping Height | 52 cm |
Shipping Weight | 7.68 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 7, TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
