Philips 243S5LSB/00 23.6" 1920x1080 5ms VGA DVI Monitor
Key features
  • S Line
  • 24 (Viewable 23.6"/59.9 cm)
  • Full HD (1920 x 1080)
Product codes
The Philips LED display using PVC, BFR-free housing is ideal for eco-friendly productivity.
Product Description Philips S-line 243S5LSB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.272 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Textured black, black hairline
Dimensions (WxDxH) - with stand 55.1 cm x 22 cm x 42 cm
Weight 3.66 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, WEEE, cETLus, RCM, ISO9241-307
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 243S5LSB/00 23...
