General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Diagonal Size |
24" |
Viewable Size |
23.8" |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 at 60 Hz |
Pixel Pitch |
0.275 mm |
Pixel Per Inch |
93 |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 / 20000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
5 ms (grey-to-grey) |
Vertical Refresh Rate |
56 - 76 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
WLED |
OSD Languages |
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features |
Sync on Green, sRGB colour management, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, SoftBlue Technology, EasyRead |
Colour |
Black, textured black |
Dimensions (WxDxH) |
54 cm x 20.2 cm x 48.3 cm - with stand |
Weight |
5 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Connectivity |
Interfaces |
VGA , DisplayPort , Audio line-in , Headphones |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+20 |
Swivel Angle |
350 |
Rotation Angle |
90 |
Height Adjustment |
130 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable |
MTBF |
70,000 hour(s) |
Compliant Standards |
Plug and Play, FCC Class B certified, TUV, ICES-003, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, EPA, cETLus, CU-EAC |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
14.1 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption (Off Mode) |
0.3 Watt |
Software / System Requirements |
Included Software |
Philips SmartControl |
OS Required |
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 54 cm - depth: 20.2 cm - height: 48.3 cm - weight: 5 kg , Without stand - width: 54 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.1 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
