Philips 243S7EYMB 24" 1920x1080 5ms VGA DVI HDMI LED Mon...
Philips 243S7EYMB 24" 1920x1080 5ms VGA DVI HDMI LED Monitor
£147.98
Delivery:
Standard: 1-3 working days
Key features
  • S Line
  • 24 (23.8"/60.5 cm diag.)
  • Full HD (1920 x 1080)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, VGA (HD-15)
Product codes
Our S Line monitor delivers business efficiency. A wide-view IPS display with SoftBlue technology is great for easy-on-the-eyes productivity. The height-adjustable, frameless display allows for tiling multiple monitors for an expanded view.
Product Description Philips S-line 243S7EYMB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black, textured black
Dimensions (WxDxH) - with stand 54 cm x 20.2 cm x 48.3 cm
Weight 5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, ICES-003, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, EPA, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 243S7EYMB 24"...
£147.98
