Philips 243V7QDSB/00 24" 1920 x 1080 5ms HD VGA DVI HDMI...
Philips 243V7QDSB/00 24" 1920 x 1080 5ms HD VGA DVI HDMI Monitor
£104.17
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 24 (23.8"/60.5 cm diag.)
  • Full HD (1920 x 1080)
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DVI, HDMI, VGA (HD-15)
Product codes
A perfect all-round display with stunning images that stretch from edge to edge, made easy on the eyes, in a compact, slim design.
Product Description Philips V-line 243V7QDSB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 21 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA
Display Position Adjustments Tilt
Colour Textured black
Dimensions (WxDxH) - with stand 54 cm x 20.9 cm x 41.5 cm
Weight 3.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, VCCI, ICES-003, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, CECP, cETLus, RCM, CU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 243V7QDSB/00 2...
£104.17
