Philips 243V7QSB/00 V-Line 24 INCH IPS VGA DVI
£113.14
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • V Line
  • 24 (23.8"/60.5 cm diag.)
  • Full HD (1920 x 1080)
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 8ms
  • Speakers: None
  • Interfaces: DVI, VGA (HD-15)
Product codes
A perfect all-round display with stunning images that stretch from edge to edge, made easy on the eyes, in a compact, slim design.
Product Description Philips V-line 243V7QSB - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Textured black
Dimensions (WxDxH) - with stand 54 cm x 20.9 cm x 41.5 cm
Weight 3.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, ICES-003, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, cETLus, RCM
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 243V7QSB/00 V-...
£113.14
