General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Energy Consumption per Year |
29 kWh |
Power Consumption (On mode) |
20 W |
Diagonal Size |
24" |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 at 60 Hz |
Pixel Pitch |
0.277 mm |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 / 10000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
1 ms (grey-to-grey) |
Vertical Refresh Rate |
56 - 75 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
170 |
Vertical Viewing Angle |
160 |
Backlight Technology |
WLED |
OSD Languages |
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features |
Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, Flicker Free technology, Mercury free |
Colour |
Textured black, glossy black |
Dimensions (WxDxH) |
56.5 cm x 23.8 cm x 43.5 cm - with stand |
Weight |
4.65 kg |
Connectivity |
Interfaces |
VGA , DVI-D (HDCP) , HDMI (HDCP) |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
-5/+20 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
1 x VGA cable |
MTBF |
30,000 hour(s) |
Compliant Standards |
Plug and Play, FCC Class B certified, TUV, BSMI, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
15.66 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption (Off Mode) |
0.5 Watt |
On / Off Switch |
No |
Software / System Requirements |
OS Required |
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 56.5 cm - depth: 23.8 cm - height: 43.5 cm - weight: 4.65 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.22 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
