Philips 252B9/00 25" 1920x1080 5ms DVI HDMI LED Monitor
£274.27
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • B Line
  • 25" (63.4 cm)
  • WUXGA (1920 x 1200)
  • Diagonal Size: 25in
  • Max Resolution: 1920 x 1200
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: VGA (HD-15), HDMI, DVI, DisplayPort
Product codes
Expand beyond boundaries with the new 16:10 frameless design Philips B Line monitor. Loaded with features to improve productivity and sustainability, this monitor takes it to the next level.
Product Description Philips B Line 252B9 - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class E
Energy Consumption per Year 31 kWh
Power Consumption (On mode) 18 W
Features USB 3.1 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.279 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Colour Gamut 107.5% sRGB, 90% NTSC (CIE 1976)
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, Haze 25%
Voltage AC 120/230 V (50/60 Hz)
Colour Black texture
Dimensions (WxDxH) - with stand 54.6 cm x 20.6 cm x 54.1 cm
Weight 5.09 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SASO, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2, HDCP 1.4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£274.27
