Philips 258B6QUEB 25" 2560x1440 5ms VGA DVI DP HDMI USB-C
£335.29
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • B Line
  • 25" (63.4 cm)
  • Quad HD (2560 x 1440)
  • Diagonal Size: 25in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, USB-C + 1 more
Product codes
Simple USB-C connection and crystal-clear IPS images. The Philips B line monitor with USB-C connector allows simple notebook docking via one cable for fast data and video to a crystal-clear IPS display, and even notebook charging.
Product Description Philips Brilliance B-line 258B6QUEB - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class B
Energy Consumption per Year 54 kWh
Power Consumption (On mode) 37 W
Features USB 3.0 hub, Fast Ethernet network adapter
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 2560 x 1440 at 60 Hz
Pixel Pitch 0.216 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort, USB
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand
Dimensions (WxDxH) - with stand 57.1 cm x 24.4 cm x 51.1 cm
Weight 7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CECP, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 258B6QUEB 25"...
£335.29
