Philips 27" Full HD LED Monitor 1920 x 1080 16:9 Black B...
Philips 27" Full HD LED Monitor 1920 x 1080 16:9 Black Bezel
£152.85
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • LED technology for vivid colors
  • Easy display performance tuning with SmartControl Lite
  • SmartContrast for rich black details
  • 16:9 Full HD display for the best viewing experience
  • HDMI-ready for Full HD entertainment
  • Mercury Free eco-friendly display
  • Compact design saves space
  • VESA mount allows for flexibility
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Enjoy vivid LED pictures on this big Philips display, it is equipped with HDMI and SmartControl Lite, it is great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Product Description Philips V-line 273V5LHSB - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 48 kWh
Power Consumption (On mode) 33 W
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour Textured black, black hairline
Dimensions (WxDxH) - with stand 64.6 cm x 24 cm x 39.8 cm
Weight 4.53 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, TCO Certified Edge
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 27" Full HD LE...
£152.85
