Philips 271B8QJKEB 27" 1920x1080 5ms DVI HDMI LED Monitor
£189.98
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology for full colors and wide viewing angles
  • Full HD display for crisp, detailed images
  • LowBlue mode for easy-on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables user-friendly ergonomic adjustments
  • Webcam pops up when you need it; secures down when you don't
  • SmartImage presets for easy optimized image settings
  • Built-in stereo speakers for multimedia
  • USB 3.0 enables fast data transfers and smartphone charging
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Get your best work done with the Philips 27" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 271B8QJKEB - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 11.5 W
Features USB Hub, 2.0 megapixel camera
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.311 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black
Dimensions (WxDxH) - with stand 62.5 cm x 22.4 cm x 55.2 cm
Weight 6.91 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, BSMI, ICES-003, SEMKO, TUV Ergo, RoHS, Lead-Free, KCC, WEEE, PSE Mark, MEPS, RCM, CU-EAC, BFR-free, Ukraine, PVC-free
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 271B8QJKEB 27"...
£189.98
