Philips 272B8QJEB/00 27" 2560x1440 5ms VGA DVI HDMI LED...
Philips 272B8QJEB/00 27" 2560x1440 5ms VGA DVI HDMI LED Monitor
£232.41
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Crystalclear images with Quad HD 2560 x 1440 pixels
  • 1.074 billion colors for smooth color gradations and detail
  • IPS technology for full colors and wide viewing angles
  • LowBlue Mode for easy on-the-eyes productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £235.90
Save £1.50
Get your best work done with the Philips 27" Quad HD monitor. Crystal-clear Quad HD gives you the space and clarity to see your work. Features like Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 272B8QJEB - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 44 kWh
Power Consumption (On mode) 30 W
Features USB Hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.233 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Textured black
Dimensions (WxDxH) - with stand 62.5 cm x 22.4 cm x 53 cm
Weight 6.9 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, MEPS, EPA, cETLus, RCM, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 272B8QJEB/00 2...
£232.41
