Philips 272P7VPTKEB/00 27" 3840x2160 VGA HDMI DP USB Mon...
£319.99
Select:
Delivery:
Key features
  • P Line
  • 27" (68.6 cm)
  • 4K UHD (3840 x 2160)
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL) + 1 more
Product codes
This advanced Philips display utilizes high-performance panel to deliver UltraClear, 4K Ultra HD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. The 10-bit display delivers rich color depth with 1.074 billion colors and 12-bit internal processing for re-creating smooth, natural colors without gradations and color banding. IPS display uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
Product Description Philips Brilliance P-line 272P7VPTKEB - LED monitor - 4K - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 61 kWh
Power Consumption (On mode) 42 W
Features 2.0 megapixel camera, USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch 0.155 mm
Brightness 350 cd/m²
Contrast Ratio 1300:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI (MHL), VGA, 2xDisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 61.4 cm x 25.7 cm x 54.8 cm
Weight 7.86 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 272P7VPTKEB/00...
£319.99
