Philips 328B6QJEB 32" 2560x1440 5ms DVI HDMI LED Monitor
£259.99
Delivery:
Standard: 1-3 working days
Key features
  • B Line
  • 32 (31.5"/80 cm diag.)
  • Quad HD (2560 x 1440)
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
Product codes
Get your best work done with the Philips 32" Quad HD monitor. Crystal-clear Quad HD gives you the space and clarity to see your work. Features like height adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 328B6QJEB - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 80 kWh
Power Consumption (On mode) 55 W
Features USB Hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch 0.2727 mm
Brightness 250 cd/m²
Contrast Ratio 1200:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Colour Black texture
Dimensions (WxDxH) - with stand 74.2 cm x 27 cm x 65.7 cm
Weight 9.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, GS, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, EPA, cETLus, CU-EAC, BFR-free, PVC-free
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 328B6QJEB 32"...
£259.99
