General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class B |
Energy Consumption per Year |
80 kWh |
Power Consumption (On mode) |
55 W |
Diagonal Size |
32" |
Viewable Size |
31.5" |
Built-in Devices |
USB Hub |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
1440p (Quad HD) 2560 x 1440 at 60 Hz |
Pixel Pitch |
0.2727 mm |
Brightness |
250 cd/m² |
Contrast Ratio |
1200:1 / 50000000:1 (dynamic) |
Colour Support |
1.07 billion colours |
Response Time |
5 ms (grey-to-grey) |
Vertical Refresh Rate |
56 - 76 Hz |
Horizontal Refresh Rate |
30 - 99 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Screen Coating |
Anti-glare, 3H Hard Coating, Haze 25% |
Backlight Technology |
WLED |
OSD Languages |
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features |
Sync on Green, SmartImage, 110% (CIE 1976) color gamut, Flicker Free technology, Mercury free, 128% sRGB colour gamut, Picture-in-Picture, Picture-by-Picture |
Colour |
Black texture |
Dimensions (WxDxH) |
74.2 cm x 27 cm x 65.7 cm - with stand |
Weight |
9.5 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
3 Watt |
Connectivity |
Interfaces |
VGA , DVI-D (dual link) (HDCP) , DisplayPort , MHL / HDMI , 2 x USB 2.0 , USB 3.0 , USB 3.0 (fast charging) , Audio line-in , Headphones |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+20 |
Swivel Angle |
340 |
Rotation Angle |
90 |
Height Adjustment |
180 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
VGA cable , DVI cable , DisplayPort cable , HDMI cable , Audio cable |
MTBF |
70,000 hour(s) |
Compliant Standards |
FCC Class B certified, TUV GS, GS, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EPA, cETLus, ISO9241-307, CU-EAC, BFR-free, PVC-free |
Security Slot Type |
Kensington security slot |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
37 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption (Off Mode) |
0 Watt |
On / Off Switch |
Yes |
Software / System Requirements |
OS Required |
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10 |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 9.5 kg , Without stand - width: 74.2 cm - depth: 6.3 cm - height: 43.8 cm - weight: 6.9 kg |
Dimensions & Weight (Shipping) |
Shipping Width |
97 cm |
Shipping Depth |
22.4 cm |
Shipping Height |
52.6 cm |
Shipping Weight |
13.41 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
ENERGY STAR Version |
7.0 |
Manufacturer Warranty |
Service & Support |
Limited warranty - 3 years |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
