Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED...
Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED Monitor
£239.98
Delivery:
Standard: 1-3 working days
Key features
  • E Line
  • 32 (31.5"/80 cm diag.)
  • Quad HD (2560 x 1440)
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images.
While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications.
Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
Product Description Philips E-line 328E9FJAB - LED monitor - curved - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class C
Energy Consumption per Year 85 kWh
Power Consumption (On mode) 58 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Panel Type VA
Aspect Ratio 16:9
Native Resolution 1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch 0.272 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, low haze
Colour Gloss black bezel with silver trim
Dimensions (WxDxH) - with stand 71.3 cm x 23.6 cm x 52.5 cm
Weight 6.78 kg
Compliant Standards FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 328E9FJAB E Li...
£239.98
