Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED...
Philips 328E9FJAB E Line 32" 2560 x 1440 5ms VGA DVI LED Monitor
£239.98
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Curved display design for a more immersive experience
  • Ultra Wide-Color wider range of colors for a vivid picture
  • VA display gives awesome images with a wide viewing angle
  • Crystal-clear images with Quad HD 2560 x 1440 pixels
  • Effortlessly smooth gameplay with AMD FreeSync technology
  • Narrow border display for seamless appearance
  • Less eye fatigue with Flicker-Free technology
  • LowBlue Mode for easy-on-the-eyes productivity
  • HDMI ensures universal digital connectivity
  • DisplayPort connection for maximum visuals
  • Built-in stereo speakers for multimedia
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Philips' VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images.
While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications.
Its optimised pixel management technology gives you a 178/178-degree extra-wide viewing angle, resulting in crisp images.
Product Description Philips E-line 328E9FJAB - LED monitor - curved - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class C
Energy Consumption per Year 85 kWh
Power Consumption (On mode) 58 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Panel Type VA
Aspect Ratio 16:9
Native Resolution 1440p (Quad HD) 2560 x 1440 at 60 Hz
Pixel Pitch 0.272 mm
Brightness 250 cd/m²
Contrast Ratio 3000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare, Haze 25%
Colour Glossy black, silver (stand)
Dimensions (WxDxH) - with stand 71.3 cm x 23.6 cm x 52.5 cm
Weight 6.78 kg
Compliant Standards FCC Class B certified, UL, TUV, BSMI, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, cETLus, RCM, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 328E9FJAB E Li...
£239.98
