Philips 328P6VJEB/00 31.5" 3840x2160 VGA DVI MHL DP USB...
Philips 328P6VJEB/00 31.5" 3840x2160 VGA DVI MHL DP USB Monitor
£379.99
Select:
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • P Line
  • 32 (viewable 31.5"/80 cm)
  • 4K UHD (3840 x 2160)
  • Diagonal Size: 32in
  • Max Resolution: 3840 x 2160
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
Product codes
The expansive 32" Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in ultra-high definition.
Product Description Philips Brilliance P-line 328P6VJEB - LED monitor - 4K - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 80 kWh
Power Consumption (On mode) 55 W
Features USB 3.0 hub
Panel Type VA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.181 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 50000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Colour Black texture
Dimensions (WxDxH) - with stand 74.2 cm x 27 cm x 65.7 cm
Weight 9.23 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, KUCAS, CECP, EPA, cETLus, RCM, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 328P6VJEB/00 3...
£379.99
