Philips 328P6VJEB/00 31.5" 3840x2160 VGA DVI MHL DP USB...
Philips 328P6VJEB/00 31.5" 3840x2160 VGA DVI MHL DP USB Monitor
£409.99
Select:
46 in stock
Delivery:
Standard: 1-3 working days
Key features
  • P Line
  • 32 (viewable 31.5"/80 cm)
  • 4K UHD (3840 x 2160)
Product codes
The expansive 32" Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in ultra-high definition.
Philips Brilliance P-line 328P6VJEB - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
80 kWh
Power Consumption (On mode)
55 W
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.181 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments
Textured black
74.2 cm x 27 cm x 65.7 cm
9.23 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, J-MOSS, TCO Certified Edge, KUCAS, CECP, EPA, cETLus, RCM, CU-EAC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 328P6VJEB/00 3...
£409.99
