Philips 329P9H 32" 3480x2160 5ms HDMI LED Monitor
£838.72
Delivery:
Standard: 1-3 working days
Key features
  • Brilliant performance
  • UltraClear 4K UHD (3840 x 2160) resolution for precision
  • IPS technology for full colors and wide viewing angles
  • Built-in USB-C docking station
  • Built-in KVM switch to easily switch between sources
  • Designed for the way you work
  • MultiView enables simultaneous dual connect and view
  • Securely sign in with pop-up webcam with Windows Hello
  • SmartErgoBase enables user-friendly ergonomic adjustments
  • LowBlue mode for easy-on-the-eyes productivity
  • Sustainable Eco-design
  • PowerSensor saves up to 80% energy costs
  • LightSensor for the perfect brightness with minimal power
  • Diagonal Size: 32in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £842.21
Save £1.50
When every detail matters, Philips Brilliance 32" 4K display delivers crisp visuals with accurate colour. Convenient features like USB-C docking and a secure pop-up webcam with Windows Hello increase your productivity.
Product Description Philips P-line 329P9H - LED monitor - 4K - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 80 kWh
Power Consumption (On mode) 55 W
Features USB Hub, KVM Switch, 2.0 megapixel camera
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.182 mm
Brightness 350 cd/m²
Contrast Ratio 1300:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Colour Black texture
Dimensions (WxDxH) - with stand 71.5 cm x 24.6 cm x 63.6 cm
Weight 10.63 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, WEEE, EPA, cETLus, China RoHS, CU-EAC, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, HDCP 2.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips 329P9H 32" 348...
£838.72
