A durable, anti-glare touchscreen for flexible use, with articulating stand to angle as you need. Advanced In-Cell Touch (AIT) offers a slimmer look, superior touch sensitivity for quick response, outstanding and clearer visibility.
SmoothTouch display for natural, fluid touch response
This Philips display uses Projected capacitive 10-point touch technology for fluid response. You can fully utilise the new capabilities of touch-based applications and bring your older applications to life. Touch-type with 10 fingers or play exciting interactive games with your friends. Collaborate with colleagues interactively at work or school environment and increase your productivity and efficiency.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
DisplayPort connection for maximum visuals
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
EasyRead mode for a paper-like reading experience
SmartStand with adjustable angles, boosts productivity
Philips SmartStand allows for flexible adjustment of the screen. Its Z-type structure with smooth tilt, height adjustment and folding capabilities enables you to use it in various ergonomic positions. You can set the stand in upright position for better touch control or recline it backwards, making it easy for you to draw or annotate. It even allows you to put the screen almost flat on the table for some applications when required.
Product Description | Philips B Line 242B1TC - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" - touchscreen | Energy Class | Class E | Power Consumption (On mode) | 18 W | Features | USB 3.2 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 102% sRGB, 83% Adobe RGB, 88% NTSC | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, tilt, Fold | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black texture | Dimensions (WxDxH) - with stand | 54 cm x 22.7 cm x 40.3 cm | Weight | 6.67 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, CU-EAC, TUV Eye Comfort certified, EAEU RoHS |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 3.2 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, Lead-free, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, sRGB Mode |
Dimensions (WxDxH) | 54 cm x 22.7 cm x 40.3 cm - with stand |
Weight | 6.67 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Input | |
Type | Touchscreen |
Connectivity | |
Interfaces | VGA , DisplayPort 1.2 , HDMI , USB 3.2 upstream , 2 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+90 |
Height Adjustment | 183 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-A to USB-B cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18 kWh/1000h |
Power Consumption (Typical) | 15.6 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54 cm - depth: 22.7 cm - height: 40.3 cm - weight: 6.67 kg , Without stand - width: 54 cm - depth: 5.1 cm - height: 32.3 cm - weight: 3.34 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62 cm |
Shipping Depth | 14 cm |
Shipping Height | 42 cm |
Shipping Weight | 9.01 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
