Philips B Line 243B9 24" 1920x1080 4ms VGA HDMI DisplayP...
FREE DELIVERY
Philips B Line 243B9 24" 1920x1080 4ms VGA HDMI DisplayPort IPS LED Monitor
£199.98
48 left in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Connect your notebook with one USB-C cable
  • SmartErgoBase enables user-friendly ergonomic adjustments
  • Less eye fatigue with Flicker-Free technology
  • LowBlue Mode for easy-on-the-eyes productivity
  • HDMI ensures universal digital connectivity
  • PowerSensor saves up to 80% energy costs
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, USB-C + 1 more
Product codes
The Philips B line monitor with USB-C docking replaces cable clutter. View Full HD image and recharge your laptop all at the same time with a single USB-C cable. SmartErgo base, Flicker-free and LowBlue mode make work easy on the eyes.
Product Description Philips B Line 243B9 - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 14.8 W
Adaptive-Sync Technology VESA Adaptive-Sync
Features USB 3.2 hub, USB PD 65 Watt
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Colour Gamut 104% sRGB, 90% NTSC (CIE 1976)
Input Connectors HDMI, VGA, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Haze 25%, anti-glare 3H hardness
Voltage AC 120/230 V (50/60 Hz)
Colour Black texture
Dimensions (WxDxH) - with stand 54.1 cm x 21.6 cm x 52.2 cm
Weight 5.19 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SASO, SEMKO, CCC, TUV Ergo, DDC/CI, RoHS, WEEE, KUCAS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2, HDCP 1.4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£199.98
