Philips B Line 243B9H 24" LED 1920x1080 4ms HDMI VGA USB
£292.72
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect your notebook with one USB-C cable
  • Power and recharge a compatible notebook from the monitor
  • IPS technology for full colors and wide viewing angles
  • Securely sign in with pop-up webcam with Windows Hello
  • Less eye fatigue with Flicker-Free technology
  • LowBlue Mode for easy on-the-eyes productivity
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C, VGA (HD-15)
Product codes
The Philips B line monitor with USB-C replaces cable clutter. View Full HD image and recharge your laptop, all at the same time with a single USB-C cable. A secure pop-up webcam with Windows Hello offers a personalized, greater security.
Product Description Philips B Line 243B9H - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Power Consumption (On mode) 14.8 W
Features Microphone, 2.0 megapixel camera, USB 3.2/USB-C hub, USB PD 65 Watt
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort, USB-C
Built-in Webcam 2 Megapixel - 1920 x 1080
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Haze 25%, anti-glare 3H hardness
Voltage AC 120/230 V (50/60 Hz)
Colour Black texture
Dimensions (WxDxH) - with stand 54.1 cm x 21.6 cm x 52.2 cm
Weight 5.44 kg
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, CU-EAC, EAEU RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£292.72
