Philips B-Line 346B1C 34" 3440x1440 5ms HDMI DisplayPort...
Philips B-Line 346B1C 34" 3440x1440 5ms HDMI DisplayPort USB-C Curved LED Monitor
£459.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Better view, better productivity
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
  • VA display delivers awesome images with wide viewing angles
  • MultiView enables simultaneous dual connect and view
  • Built-in KVM switch to easily switch between sources
  • Effortlessly smooth action with Adaptive-Sync technology
  • Designed for the way you work
  • Built-in USB-C docking station
  • Less eye fatigue with Flicker-Free technology
  • LowBlue Mode for easy-on-the-eyes productivity
  • EasyRead mode for a paper-like reading experience
  • Tilt, swivel and height-adjust for an ideal viewing position
  • VESA mount allows for the perfect setup
  • Designed for sustainability
  • PowerSensor saves up to 80% energy costs
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £462.49
Save £1.50
The Philips B line 34" curved UltraWide display gives wrap-around view of your work. All-in-one USB-C and ergonomic stand design make for optimal working conditions. Eye comfort features with TUV certified to reduce eye fatigue.
Product Description Philips B Line 346B1C - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class B
Energy Consumption per Year 79 kWh
Power Consumption (On mode) 54 W
Curved Screen Yes
Features KVM Switch, Gigabit Ethernet network adapter, USB 3.2 Gen 1 hub
Panel Type VA
Aspect Ratio 21:9
Native Resolution Ultra WQHD 3440 x 1440 at 100 Hz
Pixel Pitch 0.232 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare, 2H Hard Coating, Haze 25%
Colour Black texture
Dimensions (WxDxH) - with stand 80.7 cm x 25 cm x 60.1 cm
Weight 11.49 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, SEMKO, DDC/CI, RoHS, ISO 9241-307, TUV Bauart, EPA, cETLus, CU-EAC, DisplayPort 1.2, HDCP 2.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips B-Line 346B1C...
£459.00
