General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class B |
Energy Consumption per Year |
82 kWh |
Power Consumption (On mode) |
56 W |
Diagonal Size |
32" |
Built-in Devices |
USB 3.0 hub |
Panel Type |
A-MVA |
Aspect Ratio |
16:9 |
Native Resolution |
QHD 2560 x 1440 at 60 Hz |
Pixel Pitch |
0.277 mm |
Brightness |
300 cd/m² |
Contrast Ratio |
3000:1 / 50000000:1 (dynamic) |
Colour Support |
1.07 billion colours |
Response Time |
12 ms (typical); 4 ms (grey-to-grey) |
Vertical Refresh Rate |
23 - 76 Hz |
Horizontal Refresh Rate |
15 - 99 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
WLED |
OSD Languages |
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features |
Picture in picture, picture by picture, Sync on Green, sRGB colour management, HDCP, SmartResponse, MultiView, SmartImage, Mobile High-Definition Link (MHL), Smart Ergo base, SmartControl Premium, Crystal Clear Quad HD, SmartConnect, Flicker Free technology, BFR/PVC-free, side-by-side, Mercury free |
Colour |
Textured black |
Dimensions (WxDxH) |
74.2 cm x 27 cm x 65.7 cm - with stand |
Weight |
10.76 kg |
Audio |
Type |
Speakers - stereo - internal |
Output Power / Channel |
3 Watt |
Connectivity |
Interfaces |
VGA , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 , Audio line-in , Headphones , 2 x USB 2.0 , DVI (HDCP) |
Mechanical |
Display Position Adjustments |
Height, pivot (rotation), swivel, tilt |
Tilt Angle |
-5/+20 |
Swivel Angle |
340 |
Rotation Angle |
90 |
Height Adjustment |
180 mm |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
MTBF |
70,000 hour(s) |
Compliant Standards |
Plug and Play, FCC Class B certified, VCCI, BSMI, SEMKO, CCC, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, KC, CECP, EPA, cETLus, CU-EAC |
Power |
Power Supply |
Internal |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Stand by |
0.5 Watt |
On / Off Switch |
Yes |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 10.76 kg , Without stand - width: 74.2 cm - depth: 6.1 cm - height: 43.8 cm - weight: 7.8 kg |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
