Philips BDM3270QP/00 32" 2560x1440 VGA DVI HDMI Monitor
£370.11
Delivery:
Key features
  • 32" / 81.3 cm
  • Quad HD (2560 x 1440)
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Product codes
This Philips display will amaze you with its Crystal clear Quad HD images and brilliant colors. MultiView allows active dual connect and view.
Product Description Philips Brilliance BDM3270QP - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 82 kWh
Power Consumption (On mode) 56 W
Features USB 3.0 hub
Panel Type A-MVA
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.277 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 50000000:1 (dynamic)
Response Time 12 ms (typical); 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI, DisplayPort, VGA
Speakers Internal
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 74.2 cm x 27 cm x 65.7 cm
Weight 10.76 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, VCCI, BSMI, SEMKO, CCC, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, TCO Certified Edge, KC, CECP, EPA, TCO Displays 6.0, cETLus, CU-EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips BDM3270QP/00 3...
£370.11
