Philips BDM3270QP2/00 32" 2560x1440 4ms VGA DVI HDMI DP...
Philips BDM3270QP2/00 32" 2560x1440 4ms VGA DVI HDMI DP USB Monitor
Key features
  • 32" / 81.3 cm
  • Quad HD (2560 x 1440)
Product codes
This display form Philips delivers Crystalclear, Quad HD 2560x1440 pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like Displayport, HDMI, Dual link DVI, the screen will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, the display will give you Crystalclear images.
Philips AMVA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, webbrowsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in 90 degree pivot mode.
Philips Brilliance BDM3270QP2 - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Power Consumption (On mode)
60 W
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments
Textured black
74.2 cm x 27 cm x 65.7 cm
10.76 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, VCCI, BSMI, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, WEEE, PSE Mark, KC, CECP, cETLus, CU-EAC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips BDM3270QP2/00...
