The expansive 43" class Ultra HD professional Philips display gives you the room to spread out, see the big picture and all the details in 4K Ultra High Definition (four times the resolution of Full HD).
Philips Brilliance BDM4350UC - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class B
Energy Consumption per Year
146 kWh
Power Consumption (On mode)
100 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.2451 mm
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI(MHL), 2xDisplayPort, VGA
Screen Coating
UltraClear
Glossy black with textured back cover, textured silver stand
96.8 cm x 25.9 cm x 63 cm
9.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, KUCAS, CECP, EPA, EAC, cETLus, China RoHS, RCM
Display Type
Energy Class
Class B
146 kWh
100 W
Diagonal Size
43"
Viewable Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
UltraClear
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, Sync on Green, sRGB colour management, MultiView, SmartImage, SmartConnect, Flicker Free technology, BFR/PVC-free, slim bezel design, Mercury free, PBP, SmartUniformity, USB 3.0 Fast Charge
96.8 cm x 25.9 cm x 63 cm - with stand
9.72 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
VGA , 2 x MHL / HDMI , 2 x DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
Flat Panel Mount Interface
200 x 200 mm
MTBF
70,000 hour(s)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 96.8 cm - depth: 25.9 cm - height: 63 cm - weight: 9.72 kg , Without stand - width: 96.8 cm - depth: 8.2 cm - height: 56.2 cm - weight: 9.4 kg
ENERGY STAR Certified
20 - 80%
Customer reviews
