Philips Brilliance P-Line 22" 1680x1050 5ms VGA DVI-D LE...
£184.40
Select:
Delivery:
Key features
  • P Line
  • 22" (55.9 cm)
  • 1680 x 1050
Product codes
The Philips PowerSensor LED display using post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Product Description Philips Brilliance P-line 220P4LPYES - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Features USB Hub
Panel Type TN
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Speakers Integrated
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black with black stand, textured sliver with black stand
Dimensions (WxDxH) - with stand 50.4 cm x 22 cm x 51.7 cm
Weight 5.5 kg
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Brilliance P-L...
£184.40
