Philips Brilliance P-line 349P7FUBEB 34" Curved LED Monitor
NEW
Curved display design for a more immersive experience
£649.00
Delivery:
Standard: 1-3 working days
Key features
  • Curved display design for a more immersive experience
  • Narrow border display for seamless appearance
  • Ultra Wide-Color wider range of colors for a vivid picture
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
  • MultiView enables active dual connect and view at the same time
  • 100 Hz refresh rates for ultra-smooth images
  • All your connections through one USB-C cable
  • USB 3.0 Hub for convenient access and fast charging
  • LowBlue Mode for easy-on-the-eyes productivity
  • Tilt, swivel and height-adjust for an ideal viewing position
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
See more and do more with the Philips Brilliance 34" curved ultra-wide display. A crystal-clear wide Quad HD curved display puts you at the centre of the desktop. All-in-one USB-C and a height-adjustable stand make for the ultimate set-up.
Product Description Philips Brilliance P-line 349P7FUBEB - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class C
Energy Consumption per Year 113 kWh
Power Consumption (On mode) 77 W
Curved Screen Yes
Features USB 3.0 hub
Panel Type MVA
Aspect Ratio 21:9
Native Resolution Ultra WQHD 3440 x 1440 at 100 Hz
Pixel Pitch 0.232 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare, Haze 25%
Colour Silver, textured black
Dimensions (WxDxH) - with stand 81 cm x 31.1 cm x 62.1 cm
Weight 9.6 kg
Compliant Standards Plug and Play, TUV, GS, SEMKO, CB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, RCM, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Brilliance P-l...
£649.00
