Philips Brilliance P-line 499P9H 49" 5120x1440 5ms HDMI...
Philips Brilliance P-line 499P9H 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved LED Monitor
£908.47
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • SuperWide screen designed to replace multiscreen setups
  • MultiView enables simultaneous dual connect and view
  • Curved display for a more immersive experience
  • Effortlessly smooth action with Adaptive-Sync technology
  • Built in USB-C docking station
  • Built-in KVM switch to easily switch between sources
  • Diagonal Size: 49in
  • Max Resolution: 5120 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £911.96
Save £1.50
Wide open possibilities with two high-performance monitors in one
Our award-winning 49" curved 32:9 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like USB-C and pop-up webcam with Windows Hello deliver the performance and convenience you expect.
Product Description Philips Brilliance P-line 499P9H - LED monitor - curved - 49"
Device Type LED-backlit LCD monitor - 49"
Energy Class Class B
Energy Consumption per Year 114 kWh
Power Consumption (On mode) 78 W
Curved Screen Yes
Features Microphone, KVM Switch, USB 3.1 hub, 1080p webcam
Panel Type VA
Aspect Ratio 32:9
Native Resolution Dual Quad HD 5120 x 1440 at 60 Hz
Pixel Pitch 0.233 mm
Brightness 450 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare, 2H Hard Coating, Haze 25%
Colour Textured black
Dimensions (WxDxH) - with stand 119.4 cm x 30.3 cm x 56.8 cm
Weight 15.3 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, KCC, WEEE, PSE Mark, MEPS, J-MOSS, E-Standby, KC, CECP, CEL, EPA, cETLus, RCM, CU-EAC, Ukraine, Mercury-free
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Brilliance P-l...
£908.47
