Wide open possibilities with two high-performance monitors in one
Our award-winning 49" curved 32:9 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like USB-C and pop-up webcam with Windows Hello deliver the performance and convenience you expect.
Product Description | Philips Brilliance P-line 499P9H - LED monitor - curved - 49" | Device Type | LED-backlit LCD monitor - 49" | Energy Class | Class B | Energy Consumption per Year | 114 kWh | Power Consumption (On mode) | 78 W | Curved Screen | Yes | Features | Microphone, KVM Switch, USB 3.1 hub, 1080p webcam | Panel Type | VA | Aspect Ratio | 32:9 | Native Resolution | Dual Quad HD 5120 x 1440 at 60 Hz | Pixel Pitch | 0.233 mm | Brightness | 450 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 2H Hard Coating, Haze 25% | Colour | Textured black | Dimensions (WxDxH) - with stand | 119.4 cm x 30.3 cm x 56.8 cm | Weight | 15.3 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, KCC, WEEE, PSE Mark, MEPS, J-MOSS, E-Standby, KC, CECP, CEL, EPA, cETLus, RCM, CU-EAC, Ukraine, Mercury-free | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 49" |
Viewable Size | 48.8" |
Curved Screen | Yes (1800R) |
Built-in Devices | Microphone, KVM Switch, USB 3.1 hub, 1080p webcam |
Panel Type | VA |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 48 - 70 Hz |
Horizontal Refresh Rate | 30 - 230 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Polish, Finnish, Russian, Dutch, Greek, Turkish, Japanese, Korean |
Features | Sync on Green, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, SmartUniformity, Quad & Dual Windows PBP, Adaptive-Sync technology, 121% sRGB colour gamut, EasyRead, 103% NTSC colour gamut, sRGB Mode, Picture-by-Picture, HDR 400 compatible, 99.67% BT.709 colour gamut, DCI-P3 94.62% colour gamut, 91% Adobe RGB colour gamut, Windows 10 Hello |
Dimensions (WxDxH) | 119.4 cm x 30.3 cm x 56.8 cm - with stand |
Weight | 15.3 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | DisplayPort (HDCP) , 2 x HDMI (HDCP) , USB-C 3.1 Gen 2 upstream (power up to 65W) , USB 3.1 upstream (Type B) , USB 3.1 downstream with Battery Charging 1.2 (Type A) , 2 x USB 3.1 downstream (Type A) , Headphones , Network (RJ-45) |
Mechanical | |
Tilt Angle | -5/+10 |
Swivel Angle | 40 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | HDMI cable , DisplayPort cable , USB-A to USB-B cable , USB-C cable , USB-C to USB-A cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 45 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 119.4 cm - depth: 30.3 cm - height: 56.8 cm - weight: 15.3 kg , Without stand - width: 119.4 cm - depth: 15.6 cm - height: 36.9 cm - weight: 11 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 130.8 cm |
Shipping Depth | 38.4 cm |
Shipping Height | 55.3 cm |
Shipping Weight | 21.48 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 7.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
