Philips E-Line 27" Full HD LED Monitor with Speakers VGA...
Philips E-Line 27" Full HD LED Monitor with Speakers VGA DVI HDMI
Key features
  • E Line
  • 27" (68.6 cm)
  • Full HD (1920 x 1080)
Product codes
UltraColor technology delivers a wider spectrum of colors for a more brilliant picture. UltraColor wider color gamut produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive and vivid colors from UltraColor technology. IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colors, making them ideal not only for photos, movies and web browsing, but also for professional applications that demand color accuracy and consistent brightness at all times.
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a perfect solution to regulate brightness and reduce flicker for more comfortable viewing. SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for perfect digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
The discreetly placed EasySelect menu toggle key allows you to make quick and easy adjustments to monitor settings in the on-screen display menu. SmartImage Lite is an exclusive Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
Philips E-line 276E7QDAB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
31 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Glossy black
61.6 cm x 17.9 cm x 46.8 cm
4.33 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, TCO Displays, RCM, CU-EAC
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips E-Line 27" Ful...
