Philips Headphone Stereo 0334
£39.44
33 in stock
Delivery:
Standard: 1-3 working days
  • Recommended Use: [N/A]
  • Connectivity: Wired
  • Earcover : Binaural
  • Stock Status: In Stock
Product codes
Outstanding audio quality with Philips transcription headphones
The lightweight under-the-chin style headphones with dual sound system are designed to deliver excellent sound quality, with soft ear cushions for wearing comfort, and a hanging bracket that attaches the headset to a monitor.
Superior audio quality
  • A 14 mm speaker driver optimizes high audio quality
  • Gold-plated plug ensures an ultra reliable connection
  • Neodymium magnet enhances sensitivity and sound quality
For optimal results
  • Lightweight design improves comfort for prolonged use
  • Under chin style to fit all ears for better comfort
  • 3 meter/10-foot cable for freedom to move about your work area
Small enough for optimum wearing comfort, yet large enough to deliver crisp, non-distorted sound, the 14 mm speaker driver is the ideal size to deliver high quality sound.
The precious-metal gold finishing on the plug will produce a more reliable connection for better audio quality.
Neodymium is the best material for producing a strong magnetic field for greater sensitivity and higher overall sound quality.
The durable, lightweight quality materials enhance comfort for extended wearing.
Designed for an under-the-chin fit for better comfort.
The 3 meter/10-foot cable gives you the freedom to move around your work area without having to remove the headphones.
Product Description Philips LFH0334 - headphones
Product Type Headphones - wired - 3.5 mm jack
Headphones Form Factor Under-chin
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Audio Specifications Sensitivity 103 dB
Diaphragm Type PET
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Headphone Ster...
£39.44
