Extend your evenings with Philips Hue outdoor lighting. Set the right ambiance on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
Product Description | Philips Hue Lily Base and Extension Kit - garden spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 4) | Product Type | Garden spot light | Recommended For | Patio | Light Source Type | LED | Packaged Quantity | 4 (specifications are for single item) | Style | Functional | Cable Length | 0.5 m | Colour | Black | Wattage | 8 W | Wattage Equivalent | 40 W | Energy Efficiency Class | E | Colour of Illumination | 16 million colours | Colour Temperature | 2000-6500 K | Luminous Power | 350 - 1770 lumens | Dimmable | Yes | Intelligent Assistant | Siri, Google Assistant, Alexa - indirect | Platform | Hue | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Position Adjustments | Tilting base |
Waterproof | Yes |
Features | Double insulated, weatherproof, outdoor usage, ground spike, remote controlled, dustproof, non-replaceable light bulb, interconnectable, waterproof, app-controlled, power on/off timer, voice control, LowVolt system, wireless dimmer switch |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 8 W |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Required |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Compatible Application | Philips Hue App |
Intelligent Assistant | Siri, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Aluminium |
Body Colour | Black |
Included Accessories | Power supply, ground spike, power plug |
Package | Box |
Compliant Standards | IP65 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 7.112 cm |
Height | 19.304 cm |
Length | 8.382 cm |
Weight | 3.18 kg |
Dimensions & Weight Details | Ground spike height: 17.27 cm |
Shipping Dimensions (WxDxH) / Weight | 24 cm x 31.5 cm x 22.5 cm / 4.45 kg |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
