The Appear Wall Lantern offers 16 million colours to enhance the beauty of your home, as well as all 15 thousand shades of white to brighten your yard or enhance security. Designed to beam a direct, triangular-shaped wash of light both up and down your wall, the Appear outdoor light from Philips is a smart choice for the front porch. With an integrated LED and Hue technology, you can choose between bright, colourful light or warm white light to illuminate your outdoor space. It's made from high-quality aluminium and synthetics that have been performance-tested in outdoor conditions.
Colourful and smart lighting
Highlight objects, trees or pathways and make your outdoors a stand-out space. This light is equipped with 16 million colours and all shades of white light so you can create the exact lighting effect you want. Use your lantern to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for Spring or even an eerie purple glow to create the most haunted house on the street this Halloween.
Designed for the outdoors
Specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
*Requires Philips Hue Bridge
A Philips Hue Bridge is required for smart lighting control and available to purchase separately. Once connected, you'll experience the full potential of this smart light and can use the Philips Hue app to control it from your smart phone or tablet. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple HomeKit, and the Google Assistant to allow you to control your lights with your voice.
Product Description | Philips Hue Appear - wall lamp - LED light bulb - 8 W - 16 million colours/tunable white - 2000-6500 K - black (pack of 2) | Product Type | Wall lamp | Recommended For | Garden | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Supported Light Bulbs Qty | 1 | Dimmer | Yes | Colour | Black | Wattage | 8 W | Colour of Illumination | 16 million colours/tunable white | Colour Temperature | 2000-6500 K | Luminous Power | 710 - 1180 lumens | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Features | Weatherproof, outdoor usage |
Light Source | |
Wattage | 8 W |
Colour Rendering Index | 80 |
Lifetime | 25000 hours |
Features | Light scheduling, app-controlled, weatherproof |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Product Material | Metal |
Body Colour | Black |
Compliant Standards | IP44 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 8.4 cm |
Depth | 11.7 cm |
Height | 24 cm |
Shipping Dimensions (WxDxH) / Weight | 13.8 cm x 15 cm x 21.6 cm / 750 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
