Get in the mood with warm to cool white smart lights
Use over 50,000 shades of warm to cool white light to put you in the mood to work, play, or relax — no matter what time of day it is. Start your morning off on the right foot with cool, energising bright white light, or settle down for the night with golden tones.
Play with smart colour lights
There’s no limit with Philips Hue: with over 16 million colours, you can transform your home into the perfect party venue, bring a bedtime story to life and much more. Use preset, coloured light scenes to evoke the feeling of summer any time you'd like, or use your own photo to relive a special memory.
Away-from-home smart light control
The Philips Hue app gives you complete control over your lights, even if you're not at home. Switch your lights off and on remotely using just the app to ensure your home is always lit the way you want it.
Sync films, TV programmes, music, and games to smart lights
Bring your entertainment to new heights by syncing the action on the screen or the beat of your music to your smart lights.* Choose the way you'd like to sync your lights to your film, music (including with our Spotify integration!), TV programme or game and watch as the colour-capable lights in your Entertainment area react. *Hue Bridge required
Wireless control with included dimmer switch
With the battery-powered dimmer switch, you can control up to 10 smart lights simultaneously. The switch – which can be removed from its wall mount and used as a remote control – allows you to dim and brighten your lights or cycle through four preset light recipes
Product Description | Philips Hue Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - B22 - 9 W - total: 18 W - 16 million colours/warm to cool white light - 2000-6500 K | Product Type | Wireless lighting set | Light Source Type | 2 x LED light bulb | Supported Light Bulbs Qty | 50 | Total Wattage | 18 W (equivalent 120 W) | Dimmer | Yes | Shape | A60 | Socket Type | B22 | Wattage | 9 W | Wattage Equivalent | 60 W | Energy Efficiency Class | F | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 1100 lumens | Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 100 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 9 W |
Energy Consumption per 1000h | 9 kWh |
Power Factor | 0.5 |
Colour Rendering Index | 80 |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Instant full light, app-controlled |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Compatible Application | Philips Hue App |
Supported Host Device Platform | iOS, Android |
Miscellaneous | |
Included Accessories | Power adapter, wireless bridge, network cable, dimmer switch |
Package | Box |
Compliant Standards | IEEE 802.15.4 |
Warranty | 2 years |
Dimensions & Weight | |
Dimensions & Weight Details | Wireless bridge height: 26 mm , Light bulb height: 110 mm x diameter: 60 mm - 76 g , Dimmer switch - width: 35 mm x depth: 11 cm x height: 9.2 cm - 37 g , Wall plate - width: 70 mm x depth: 14 mm x height: 115 mm |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
