Hue Centura offers the perfect splash of ambiance for any occasion. Ideal for your living room and bedroom. Control via Bluetooth to instantly set light scenes in one room or pair with a Hue Bridge to unlock the full suite of features.
Product Description | Philips Hue White and Color Ambiance Centura - recessed spot light - LED spot light bulb - GU10 - 5.7 W - 16 million colours/warm white to cold white light - 2000-6500 K - white (pack of 3) | Product Type | Recessed spot light | Recommended For | Kitchen, living room, bedroom, study room, home office | Light Source Type | LED spot light bulb | Packaged Quantity | 3 (specifications are for single item) | Supported Light Bulbs Qty | 1 | Dimmer | Yes | Colour | White | Socket Type | GU10 | Wattage | 5.7 W | Colour of Illumination | 16 million colours/warm white to cold white light | Colour Temperature | 2000-6500 K | Luminous Power | 350 lumens | Intelligent Assistant | Google Assistant, Alexa | Platform | Hue | Communications Technology | Bluetooth | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Features | Double insulated, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, voice control |
Light Source | |
Wattage | 5.7 W |
Lifetime | 15000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Miscellaneous | |
Product Material | Synthetics |
Body Colour | White |
Package | Box |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 9 cm |
Weight | 198 g |
Dimensions & Weight Details | Hole cut-out diameter: 7 cm |
Shipping Dimensions (WxDxH) / Weight | 21.9 cm x 10 cm x 20.9 cm / 856 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
