We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Give your largest spaces bright, colorful smart light with these two E27 smart bulbs. With a brightness equivalent to a traditional 100 W bulb, these bulbs can fill living rooms, kitchens and more with color.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: A67 - E27 - 13.5 W - 16 million colours/warm to cool white light - 2000-6500 K | Light Source Type | LED light bulb | Shape | A67 | Socket Type | E27 | Wattage | 13.5 W | Wattage Equivalent | 100 W | Energy Efficiency Class | F | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 1200 - 1521 lumens | Beam Angle | 360 degree(s) | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
Light Source | |
Shape | A67 |
Socket Type | E27 |
Wattage | 13.5 W |
Energy Consumption per 1000h | 14 kWh |
Power Factor | 0.9 |
Colour Rendering Index | 85 |
Dimmable | Yes |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 67 mm |
Length | 131 mm |
Shipping Dimensions (WxDxH) / Weight | 7.2 cm x 7.2 cm x 21 cm / 210 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
