We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - B22 - 6.5 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Shape | A60 | Socket Type | B22 | Wattage | 6.5 W | Wattage Equivalent | 40 W | Energy Efficiency Class | F | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 800 lumens | Dimmable | Yes | Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
General | |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 6.5 W |
Energy Consumption per 1000h | 7 kWh |
Power Factor | 0.8 |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, app-controlled |
Power Requirements | |
Power Consumption Operational | 6.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Supported Host Device Platform | iOS, Android |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 109 mm |
Weight | 72 g |
Shipping Dimensions (WxDxH) / Weight | 14.6 cm x 7.2 cm x 17.4 cm / 240 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
