Portable Smart Lighting - With its built-in rechargeable battery, take your smart light wherever you go. Use go as the centrepiece for a romantic dinner, or take it outdoors to create that perfect party ambiance. Enjoy from 2.5 hours of brilliant smart lighting and up to 18 hours using the 'cosy candle' Light effect
Control your lights from the Hue Go - Press the button on the portable smart light to choose from seven different light effects - Cool energising daylight, warm relaxing light, and the five dynamic light effects, or tap and hold the button to quickly cycle through colours
Control Lights With Your Voice - Works with all Echo smart speakers/displays and Google Nest devices for hands-free voice control
Product Description | Philips Hue Go - desk lamp - LED - 6 W - white | Product Type | Desk lamp | Light Source Type | LED | Colour | White | Wattage | 6 W | Luminous Power | 520 lumens | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Features | Built-in battery |
Light Source | |
Type | LED |
Wattage | 6 W |
Dimmable | Yes |
Lifetime | 20000 hours |
Features | Voice control |
Power Requirements | |
Internet of Things (IoT) | |
Miscellaneous | |
Product Material | Synthetics |
Body Colour | White |
Included Accessories | UK power plug |
Compliant Standards | IP20 |
Localisation | United Kingdom |
Warranty | 2 years |
Dimensions & Weight | |
Width | 15 cm |
Height | 7.9 cm |
Length | 15 cm |
Weight | 625 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
