We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Extend the length of your Philips Hue ambiance gradient light strip, covering a larger area with a blend of colorful light.
Product Description | Philips Hue White and Color Ambiance Gradient - light strip extension - LED - 12.3 W - 2000-6500 K - white | Product Type | Light strip extension | Light Source Type | LED | Light Cover Type | Diffuser | Usage Modes | Bright, spring blossom, savannah sunset, smaragd island | Colour | White | Wattage | 12.3 W | Colour Temperature | 2000-6500 K | Luminous Power | 1000 lumens | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
General | |
Features | Self-adhesive, indoor usage, Android compatible, iOS compatible, flexible, cuttable, app-controlled, extendable (up to 10 m) |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 12.3 W |
Dimmable | Yes |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Compatible Application | Philips Hue App |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Silicone |
Body Colour | White |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 14.5 mm |
Height | 5.5 mm |
Weight | 80 g |
Shipping Dimensions (WxDxH) / Weight | 14.6 cm x 14 cm x 7.2 cm / 90 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
